Re: where in SF for case weld
Dan O /
Brandon I used JB weld on mine and it works fine. I got a piece of flat clear plastic and mounted it to the case opening using the studs then backfilled the JB weld so I could see how much to put in there. After it dries use a dremel to clean up the edges and your ready to rock. See the picture. I put the JB on before the porting.
Dan
