Re: 12 mm stock Minarelli intake ->14 mm!
Silverfox Sullivan /
Same thing on drilling out the inlet in the cylinder. Go very slow. Stop before the bit gets to the actual opening in the cylinder wall. If you drill through into the cylinder port itself you can upset the port timing. It is OK to widen the inlet port a little but don't raise the top. After you get close, use a dremel to smooth up the transition.
You will lose acceleration but gain some top end.
  12 mm stock Minarelli intake ->14 mm!Topic by: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 09/11/07 10:25AM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: peter peter 09/11/07 11:12AM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 09/11/07 11:33AM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: peter peter 09/11/07 11:40AM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 09/11/07 12:15PM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: Silverfox Sullivan Silverfox Sullivan 09/11/07 02:02PM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 09/11/07 02:41PM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: Mark Ryan Mark Ryan 09/11/07 02:45PM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 09/11/07 02:57PM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: OG leefungchow OG leefungchow 09/11/07 05:30PM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 09/11/07 05:56PM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 09/12/07 11:58AM
  Re: 12 mm stock Minarelli intake ->14 mm!Re: Silverfox Sullivan Silverfox Sullivan 09/12/07 12:24PM
  My handiworkRe: Matt Scout The Scouting Dcon Matt Scout The Scouting Dcon 09/12/07 03:46PM
