i think i am figuring out how to build a sick moby up without buying all the parts in one expensive bundle.
so far i think a good layaway moby build goes in these steps:
1. 15:15 dellorto
2. le sweet french pipe
3. av10 (thats a given) w/cdi
4. clutch pully (given ur av10 did not have a kick start otherwise variator here and clutch pully at #6)
5. top end kit
6. performance variator
7. doppler spring
8. polini 4 pedal reed cage, and 21mm dellorto
9. engine rebuild with a performance crank, and polini bottom end.
at 8 and 9 it becomes hazy i think, you could go polini bottom or not, race crank is probably a good idea in the long run, i think its going to be my next investment.
you could ride at all the steps for a good while (at the least a month between some) till upgrading to the next part. giving the moby maniac on a budget some time to save up for the big guns
obviously this is a crude list lol
