backfire
start it find but on full gas i get back fire . i no air filter it blow it out when backfire . plus on full gas it sounds like it no power.
Re: backfire
Start with a new plug and see if that does it.
Chas
Re: backfire
dtorpuch80maxi /
ok, but this plug two days ago can it go bad that fast
Re: backfire
Is this a reed valve engine? If it is I'd say that your reed is screwed.
Otherwise check for a horribly misadjusted spark timing.
Re: backfire
check the plug gap
Re: backfire
Cleats Onionpockets /
It also sounds a lot like you have either a terrible air leak or perhaps your timing is waay too late. That happened to me when I tried to put a 70cc kit on my bike, turned out to be that I needed to advance the timing a bit.
Re: backfire
dtorpuch80maxi /
ok' so to advance. do i move the plate. or regap the point
Re: backfire
elfinbloodwillflowforever /
i would check the points,
my pinto was doing the same thing, and that was the problem.
joe
