head gaskets
just wondering about the strength of the moby headgaskets. is it alright to reanneal and normalize them more than once?
Re: head gaskets
I don't know about reannealing them, but I do know that a beer can cut to fit makes an excellent replacement.
-Zack Bandit
Re: head gaskets
You can also use valve grinding compount and lap hone the head and cylinder surfaces together, if the piston dome won't bump the plug without a gasket being there.
Re: head gaskets
I'm not really sure about the beer can. I'm pretty sure that the aluminum alloy in a beer can is much harder than the the aluminum jug and head surfaces. It's doing nothing here but taking up space. A softer aluminum or very malleable brass shim stock would probably be better.
When you remove a head gasket you should be able to see the machining and imperfections of the head imprinted onto the metal - that means it was doing it's job. I doubt you'd see anything like that on a beer can gasket no matter how much you torqued down the head.
Re: head gaskets
i make gaskets out of coke cans and they compress just fine. i see plenty of imperfections.
Re: head gaskets
WariSesi /
OP
geb that is why i am wondering about annealing the used ones.
Re: head gaskets
I've annealed them a few times and it worked just fine. Got a great seal. Make sure not to over-torch it though, it will oxidize if you heat it too much, then it gets warped and doesn't fit well anymore
Re: head gaskets
WariSesi /
OP
i was thinking of getting some copper and making a more permanent one
Re: head gaskets
I second the beer can gasket. It works. It's cheap and easy.
Re: head gaskets
🇮🇹💦 Of the Loin /
dont use one.
its not necessary
Re: head gaskets
I didn't know anything about re annealing the gasket, I just put it back on. I'm gonna take it out though and use a beer can gasket, I happen to like canned beer.
