puch mill head
This has probably been asked before, but what is a good amount to take off the cylinder head for a puch? Also, is it advisable to remove the gasket? I was looking at old posts and it seems to depend on the brand as to whether or not it is safe to do that. I don't know anything about this stuff so I would have it done at an auto place. I saw Napa mentioned.
Re: puch mill head
do it yourself.
get a block and some oil.
Even Figure 8 motion
Mild Job,, measurement reading @ 0.63mm Good for 10 extra PSI, anything more is not really needed for a Stock Carb set up.
Old thread https://www.mopedarmy.com/forums/discuss/7/30461/30461/
Re: puch mill head
I did that on my scoot, worked great. Even used a concrete block.
Re: puch mill head
- Summerai - Ben /
I don't understand how you measure that. That looks to me like you're measuring the diameter, but I know you're not. =/
Also you say .63mm is good for a stock carb set up. Would you recommend something different for a 15mm carb, 14mm intake, high flow airfilter and biturbo?
Re: puch mill head
taking off the gasket alone will improve torque.
Re: puch mill head
My bad,, stock carb to me is, 12,14,15mm bings
you measure the "lip edge" on the Dome.
Re: puch mill head
Taking it down to the fins won't cause any problems
Re: puch mill head
- Summerai - Ben /
is that what the mosquito fleet usually does steve?
Re: puch mill head
Are you serious steve?..!
That seems like far more than 3 thousandths of an inch.
Re: puch mill head
- Summerai - Ben /
how thick is the base gasket? I sanded the head down but I didn't have anyway of measuring it, so I just compared it to the base gasket. The gasket is now thicker than the lip. I left the gasket on there when I put the head back on. I don't know if I notice a difference but it did make my idle higher, so I guess that it did do something.
Re: puch mill head
yep and more
Re: puch mill head
Sand away. If the piston hits the head you can use a gasket or dremel away the area that hits the piston and sand some more. Get wild
Re: puch mill head
- Summerai - Ben /
lol... alright. I will sand it down to the fins then I guess.
Re: puch mill head
i am probably the only fleet member who doesn't do that, I say a lathe is much more accurate, I have some magnum heads and low torque maxi heads that I have turned down 25 thousandths and more,
never run gaskets, or at least nothing more than the paper thin aluminum
Re: puch mill head
i am gonna mill mine and get freaky with it- going to get as close to the spark plug as possible and see what happens- i well let ya know-
Re: puch mill head
As far as putting the head back on after this operation and removal of the head gasket, what the correct proceedure and torque specs for those head bolts? Any tricks?
Re: puch mill head
oops, i went a little to overboard and now the piston hits the head- so now i must go at it again and slightly bevel the inner edge- lets hope this works or i may have to get a new head-
Re: puch mill head
- Summerai - Ben /
make sure you run a more oily mixture after that. I forgot and ran 50:1 and seized. :(
Re: puch mill head
what would you suggest for the oil ratio after the mill job?
Re: puch mill head
- Summerai - Ben /
I have no idea obviously. lol. But you can rule out 50:1 ... dammit
Re: puch mill head
i think that i overdid this- now the piston hits the head- i have to go back to the mill and shave a little around the edge now- but will it still work- is the chamber to small???
Re: puch mill head
don't mean to steal your thunder, but that head doesnt look very flat?
Re: puch mill head
the head is flat- that is just the flash catching the sanding angles- but i did find that i have little pox of sorts that seem to have been air bubbles in the original cast- hmm... hopefully these little things won't cause any trouble-
Re: puch mill head
as long as the bubbles arnt in the actual combustion chamber it should be ok...you could probably fill them if you really wanted to
