Re: Puch Magnum X E50 E 50 Engine
Chris Paz /
The 80cc (75 really) drop right into the X50 engine.
If you just have the kick assembly you are shit out of luck unless you have a friend who is a machinist and you can get your hands on a kick start clutch assembly.
There are 2 holes in the case that match up to the tranny cover/kick start assembly. These locate everything preciesely and take the strain off the bolts.
The clutch on the kick start is special as well. There is no friction material on the outside face (where the preassure plate would connect. Instead the surface is just a metal plate. There is a gear that slots into this plate and is held captive by a bolt on the end of the crank shaft. This gear meshes with the gear on the kick start assembly. Both are precisely machined and hardened to minimize wear.
Not saying it can't be done but just that I would take a lot of work to adapt the side cover to a stock e50 case. Without the benefit of the case accepting the 75cc kits that the X50 case dose.
I'll upload some pictures of my case tonight or tomorrow
  Puch Magnum X E50 E 50 EngineTopic by: Jeff Jeff 10/08/06 09:41PM
  Re: Puch Magnum X E50 E 50 EngineRe: Daniel Daniel 10/08/06 09:44PM
  Re: Puch Magnum X E50 E 50 EngineRe: Jeff Jeff 10/08/06 09:56PM
  Re: Puch Magnum X E50 E 50 EngineRe: Daniel Daniel 10/08/06 09:59PM
  Re: Puch Magnum X E50 E 50 EngineRe: Fingers Fingers 10/08/06 10:01PM
  Re: Puch Magnum X E50 E 50 EngineRe: Jeff Jeff 10/08/06 10:07PM
  Re: Puch Magnum X E50 E 50 EngineRe: Rich Battag Rich Battag 10/08/06 10:21PM
  Re: Puch Magnum X E50 E 50 EngineRe: Jeff Jeff 10/08/06 10:22PM
  Re: Puch Magnum X E50 E 50 EngineRe: MopedKidd MopedKidd 10/08/06 11:08PM
  Re: Puch Magnum X E50 E 50 EngineRe: Daniel Daniel 10/08/06 11:17PM
  Re: Puch Magnum X E50 E 50 EngineRe: Rich Battag Rich Battag 10/08/06 11:36PM
  Re: Puch Magnum X E50 E 50 EngineRe: Mopedcustomizer Mopedcustomizer 10/09/06 11:04PM
  Re: Puch Magnum X E50 E 50 EngineRe: MopedKidd MopedKidd 10/09/06 12:21AM
  Re: Puch Magnum X E50 E 50 EngineRe: Jeff Jeff 10/08/06 11:55PM
  Re: Puch Magnum X E50 E 50 EngineRe: Daniel Daniel 10/08/06 11:57PM
  Re: Puch Magnum X E50 E 50 EngineRe: Rich Battag Rich Battag 10/09/06 12:35AM
  Re: Puch Magnum X E50 E 50 EngineRe: Chris Paz Chris Paz 10/11/06 05:20PM
  Re: Puch Magnum X E50 E 50 EngineRe: Zane F Zane F 10/11/06 05:44PM
  Re: Puch Magnum X E50 E 50 EngineRe: MopedKidd MopedKidd 10/11/06 06:51PM
  Re: Puch Magnum X E50 E 50 EngineRe: Chris Paz Chris Paz 10/11/06 07:06PM
  Re: Puch Magnum X E50 E 50 EngineRe: Chris Paz Chris Paz 10/14/06 07:03PM
  Re: Puch Magnum X E50 E 50 EngineRe: Zane F Zane F 10/11/06 07:38PM
  Re: Puch Magnum X E50 E 50 EngineRe: Daniel Van Donsel Daniel Van Donsel 10/15/06 08:12PM
