yeah that is a common goal, a really good all around set up that is gonna be reliable and pretty quick is: 1. polini 64cc kit with reed valves, that is more your high reving race kit with only one ring, the other option is the 65cc metra kit, this is about 5mph slower, but it is gonna last longer due to its lower revving, twin ring design. 2. a bigger carb is a must, i think the bing 15mm is a great carb, its not the highest performance carb, but its solid and bulletproof. 3. pipes, there are tons of options, if you want low end and want to spend money, go with the techno estoril from 50cc.nl, if you want a cheap higher end pipe the biturbo( has a nice low sound too), if you want a good high end the homoet 4p is your best bet, its loud and screams, a good all around pipe with again An emphasis on high end is gonna be the bullet, its a good price too. gearing wise, if you wanna chew up hills a 14-45 is a good combo, if you wanna have a decent, all around gearing, a 16/18-40, if you want rip on the flats and have high topend speed then something like a 22-36 will rip. if you do all of that there will be no problem attaining that goal, you should really get a racing crank as well with the higher RPMs. and break it in good, there are tons of theories on it, just search around. good luck with it, the difference is amazing, you will never be able to ride a stocker again if you do that! have fun
