help gearing please!!
my moped shifts pretty low around 15 mph how do i change that w/o loosing to much top speed
Re: help gearing please!!
nothing
All mopeds I've ever ridden have shifted at 15mph... that's the shift-point.
Dan
OMg this works on my revival great when you want to shift just kick the crank case once as hard as you can and it will shift up at 1 mph if you want it too. shift up kick the right shift down kick the left side.
if it's a TTLX you can do 2 things:
#1. cut the 2nd gear spring to make it shorter. That'll raise the shift point and have no effect on your top speed,
#2. Install a bigger front sproket. Your clutch will still shift at the same engine RPM, but since you have a high ratio it will be faster than 15 mph.
it all depends on what you want to do.
thanx for the info
