proxy.aol.com <--- says it all.
I'm not sure that you can do that without changing the power curve because the length of the "stinger" effects the expansion chamber.
this might work... but I don't know for sure.
You might try pull out that baffling material, and plugging all of the holes in the baffle. that would leave the stinger the same length, but would stop the exhaust from ever getting baffled.
turboped:
seriously... I don't like saying bad things about people... I even answer a lot of questions that most people think are too retarded to bother with. But every time I see you post something it's either completely crazy... which makes it unbelievable (meaning that it can't be believed), or your causing trouble for no reason. Can't you just stop? I'm asking nicely.
