how do i debaffle my exhaust
i want to debaffle my biturbo w/o losing any power is this possible
Re: how do i debaffle my exhaust
kick the gold peice off retard
thanks for being a dickhead but that looses power and like i said before id like to do it w/o loosing power
ok than leave it alone ass hole
haha this made me laugh
retard
dickhead
asshole
hehe funny funny
aaaa thank i guess
proxy.aol.com <--- says it all.
I'm not sure that you can do that without changing the power curve because the length of the "stinger" effects the expansion chamber.
this might work... but I don't know for sure.
You might try pull out that baffling material, and plugging all of the holes in the baffle. that would leave the stinger the same length, but would stop the exhaust from ever getting baffled.
turboped:
seriously... I don't like saying bad things about people... I even answer a lot of questions that most people think are too retarded to bother with. But every time I see you post something it's either completely crazy... which makes it unbelievable (meaning that it can't be believed), or your causing trouble for no reason. Can't you just stop? I'm asking nicely.
now Im baffled and laffled!!! tanks
hahaha wow your a dick but that was funny.
2 stroke pipes in the old days could be taken apart, sometimes the entire center core could be pulled out. Look for rivets, you can drill them out and hopefully remove the baffles. Its a matter of flow, you can drill the baffles larger or drill more holes to improve flow. You will have to rejet, the second the flow goes up the bike will lean out and that will kill power and if it leans out too much you could start melting things. If you can afford it, get an expansion chamber with a jet kit and air cleaner, that will make a whole bunch of power. Happy hot rodding.
