can i pu an airsal on a revival
i have 2002 revival mine still has the a35 engine i wanted to know if i cld put the 65cc airsal kit on it
thank you adam
Re: can i pu an airsal on a revival
yeah you can asiral is for the a35 so yea it will bolt right up
thanks
the only problem u may have is the exhaust
why is the exhaust a problem i have a bi turbo
i know at the moped shop i go to they have problems with clearance. is it on the bike if so more power to ya
i'm not really sure wat your saying i didn't buy the kit yet i alredy have a bi turbo on it
1977Mopeds.com now sells a Bi-Turbo for the Revival A35. Pretty cheap too, the only downside is that it's Flat-Black...
Dan
kinda like the flat black...
be cool on a bobber style custom job. or smitty's chopper ped hehe
Re: kinda like the flat black...
i ave a normal 1 and it works fine. Would tyhat one work better and can i put an airisal with my normal biturbo, would it worth w/ that black one?
have*
It will work fine.
Also, that flat black pipe may be good for cops that hassel you for proformance pipes.
You could always have 1977 send it here and then they send it to done in your choice I have used these people a couple times and my friend has a set of headers that have never "blued". www.jet-hot.com check it out, pretty nice. I had a whole m/c exhaust done for $175.00. It will be much cheaper.
only in NJ you get into trouble for mopeds..lol
so then why is that one specific for a revival if the normal biturbo will do the job.
and bacjk to my originl question will the arisal fit?
John Joedicke /
You have the A35 engine, the Airsal kit will fit but the pipe will need a little fabrication for the hanger bolt as the holes will not mate. Nobig deal that a little flat bar will not fix.
not true, you can in pa too
got nailed to the wall by some asshole back woods cop.
