Motobecane Cady
I have a Motobecane Cady and want to find any possible preformance stuff for this, i think its around a 1976 and its a 49.9cc. Anybody know of any websites with performance stuff for this?
Re: Motobecane Cady
what type of motor is it?
Re: Motobecane Cady
The only things i know about the motor is that its a 49.9cc 2 stroke
Re: Motobecane Cady
Remove the end part from the muffler. Remove the airbox and install a small 12v computer fan to blow air into the carb.
Re: Motobecane Cady
Do not do that.
It will make your bike run lean, and hot. 2 great ingredients for a quick seize.
It would also be loud enough to get you arrested.
There is not much available for cadys as far as aftermarket stuff.
Re: Motobecane Cady
It worked fine for me, made it a lot faster.
Re: Motobecane Cady
Are you talking about the piece of pipe that is inside the actual muffler?I wanna take off the airbox for sure and the screens and just run a filter, but im not sure about that exhaust because it is a 2 stroke and they make power according to the exhaust correct?Which bike did you do this to?
Re: Motobecane Cady
And if i get the serial number off the motor will someone run them for me somewhere?or tell me where?Thats if i cant find some manufacturers on the engine
Re: Motobecane Cady
i have a copy of the users manual and the service manual for the cady. the cady is different from all the other motobecanes. if you'd like a copy, i make can you one for a few bucks. if you're interested, email me, don't post because i don't look too often. email me at mopeddave@rogers.com
dave
Re: Motobecane Cady
Yeah, I only mean taking out the part that is inside the muffler. There is another baffle in the muffler. If you take off the whole thing then you will have performance problems. It also helps to keep the engine cool, mine would overheat unless I had it off.
I did it to a '74 Cady
Re: Motobecane Cady
Will an airsal 70cc kit fit the Cady;s m1 Engine. The kit claims to fit model series 7, 40, and 50 motobecanes. I do believe the 7 is similar to the M1
Re: Motobecane Cady
the 7 is very different than the M1. the 7 looks like a 50 or a 40 only with the gas tank at the rear see?
