I feel much better now, knowing everything has been taken care of..
Would you mind sharing the technique you use to weld copper? Perhaps you meant "solder" instead of "weld".
And maybe you can answer one other question that has always bothered me.. Do you know why copper or copper plated steel fuel lines like on an automobile always seem to use compression fittings instead of solder?
