Well it IS a high performance part therefore i cannot guarentee specific results or anything like that since there are so many different engine setups. What I do guarentee is that the bottle will be free of defects, will not leak break or otherwise be damaged (unless you screw it up purposely). They are calculated to be the correct size and SHOULD give you results if everything is installed correctly (just follow detailed instructions provided).
