I need to grind my 14mm intake so my new bing 15mm carb so it will work as a 15mm carb but how do I grind my 14mm intake. Do I just grind the the inside as much as I can? Or do I just grind the bottom of the intake where it goes to the main cylinder. I know someone else has done this before can you please just let me know where to grind and what bits for my dremmel I should use. I know I could buy the 15mm intake but I have a 2-speed puch with the high rise intake and Im not sure if I can find that one in a 15mm. Can you guys please let me know how I should grind that thing down. Thanks
