speed sprocket
im buying the 70 cc airsal kit for my 1980 puch maxi 1 speed. which sprocket should i get for best performance and is it the front or back
Re: speed sprocket
depends on what your looking for and were you live (hills)
18X40 is a good even gear, not to low and not to high.
Re: speed sprocket
18 is way to high for a one speed and hills....16 is probably what your looking for...if you drive on decent flatness, an 18 will give you good top but take a while
Re: speed sprocket
that's why I said depends on where you live.
18X40 is a good even gear.
Re: speed sprocket
18 is like the highest you can put on the pinion
Re: speed sprocket
A fabricated 22 sprocket WILL fit on the countershaft of a Puch E50 or ZA50 block with machining of the block to provide clearance for the chain.
Re: speed sprocket
Troy Brown /
where can we get one of those?back in the day some guys used a 20t sproket.
Re: speed sprocket
I've got the same ped and kit. I bought the 18 th and ran for awhile. Very poor accell so i put the 16 th back on. Much better low end and decent topend.
Re: speed sprocket
I am currently using a 20 tooth front sprocket on my ZA50.
As for where I got them, I acquired an original 20t somewhere in the late 1980s from an unknown puch model.
I could not find anymore so I decided to machine a custom 20t as seen in the attached image.
If no image is attached, go to my home page to see image.
Re: speed sprocket
Troy Brown /
is that a 20t sproket off a Derbi?
Re: speed sprocket
Yes, it is a Derbi 20t sprocket that was first machined in the center and a Puch spline was welded in place.
Re: speed sprocket
Nice job on the sprocket, and nice quotr:
"Last but not least, go to school and learn to spell!! At least make an effort and try using 5p377 cH3cK! "
Dave
Re: speed sprocket
Who cares about spelling as long as it understandable.
Besides anything GOT RIGID has to say or share
I'M ALL EARS.
any of you newbs out there should check out his web site
you may learn something from this guy. Puch76rigid.com
I think?
