RPM LIMITS ON TOMOS
DO TOMOS TARGAS HAVE A REV LIMITER BUILT IN? CAN IT BE REMOVED? CAN THE TIMING BE BUMPED UP? WHAT'S THE HIGHEST RPM I CAN REACH W/OUT BLOWING MY MOTOR? CAN THE CRANK BE BALANCED AND FLYWHEEL LIGHTENED AND BALANCED? IS IT WORTH ALL THE EFFORT? THANX.......
Re: RPM LIMITS ON TOMOS
THERE ARE NO REV LIMITERS, THE TIMING CAN BE RETARDED OR ADVANCED, HIGHEST RPM IS PROBABLY BETWEEN 6000-7000, AND EVREYTHING IS BALANCE ALREADY AND LIGHTENING THE FLYWHEEL WON'T DO TO MUCH EXCEPT KILL THE ENGINES MOMENTUM. By the way, turn the caps lock off.
my tomos race ped hits 9,000 rpm .
with a modified tccd kit and bored to the limit.
Zack Guiliano /
the entire cdi of the tomos limits rpms. you can buy an upgrade cdi.
Where can you buy the upgraded coil and how much is it?
Zack Guiliano /
Zack Guiliano /
oh i forgot to mention before im not positive about the cdi being limited but thats what ive heard from a few people at moped2.org but its pretty believable considering how many ways mopeds are purposely limited in stock performance
