puch 70 cc kit tuning
I've got a 77 puch maxi w/ a airsal 70 kit on it. Does anyone have info on the carb? I'm having trouble tuning it. It runs fine, but seems like it should have more power. And it will not idle w/ the wheel on the ground. Does anybody know any good starting points for settings of the idle and air needles. Thanks ben
Re: puch 70 cc kit tuning
did you try adjusting idle screw?also,you may want to check needle setting,set down one notch from where your at now.
