Hello All. i have a 1978 garelli that will not start, wont even try. I have a new carb, new exhaust, new head and cyl gaskets. it has spark and seems to be getting fuel, based on spark plug being slightly wet. Working rear tail light. i cleaned up the points and timing seems to be on, at least close enough to "hit". i am wondering if the compression is low. it is coming in at 5 to 1 or 75psi-ish. I thought it might be slightly low because it is a new piston ring and hone job, and it has not had a chance heat up and seat. i am open to any ideas and advice
Thanks in advance and please take care
Mike
