Motobecane rear wheel bearings…
Douglas Mackinnon /
The service literature and Treatland reference 2 different sized bearings for the rear wheel. 1- 30mm x 10mm and another @ 26 x 10. Both mine measure to be identical at 30mm O.D. Does anybody know if this changed with the last years of production or possibly my rear rim is not original?
Re: Motobecane rear wheel bearings…
Richard Eberline /
Motobecane used at least two different hubs for the rear. The brake plates are different also. Treatland sells both bearings.
Douglas Mackinnon /
Thanks for your response. I saw a “taco rating” blurb on treatland someone had posted about the bearings. Apparently, if you’ve got a particular rear axle, both bearings are the same. That’s what I’ve got.
