> Douglas Mackinnon wrote:
> I’m working in rehabbing a machine very similar to yours. You’re a bit
> ahead of me. I took my headlamp apart a few days ago. I made a sketch
> of the wires that I don’t have in front of me. I recall one of the
> whites being on a different terminal. I think the switch’s double tab
> had the 2 wires sharing spade; one of the single whites was on the back.
> That would conflict with the diagram but I’ll look when I get home.
> Did you happen to snap a picture of how the spring clips hold the glass
> in? I took them out recklessly.
Just in case you haven't done this type of spring clip, it's one side in first with it seated in the center, bend in the other side so it sticks inside the headlight ring. Trying to push it all in at once doesn't work.
