Re: Restoring a 1978 Motobecane 50V
Bob Chesarek /
Happy New Year guys! Connecting wires today and am having a problem with the brake lights not working. All the individual wires in the wiring harness tested good for continuity. When applying 12V to the white magneto wire, I have headlight, tail light and speedo lights working but no brake lights with either lever. The tail light bulb is good. I tested each individual brake light switch and I had continuity between both wires ( on the throttle side black and yellow wires for example) when the plunger on the switch is depressed like when the lever is at rest and an open circuit when the plunger is out as when you squeeze the brake lever.
Does that sound correct? Seems weird to me that you would have continuity with the plunger depressed.
I believe I have the headlight switch installed correctly (as it was when I took it apart) and the wires hooked up to it properly. On the double terminal side of the switch, I have the white double wires to the headlight and the single white wire to the speedo lights. On the opposite side of the switch, I have the black wire to the ground in the rear and the white wire to the magneto on the front terminal.
I have included the wiring diagram for your reference. Anyone good with electrical will hopefully be able to tell me what is wrong or at least something to check out.
Thanks for your replies! (edited)
  Restoring a 1978 Motobecane 50VTopic by: Bob Chesarek Bob Chesarek 12/07/22 01:32AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/07/22 07:32AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 09:24AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/07/22 09:45AM
  Re: Restoring a 1978 Motobecane 50VRe: P D P D 12/07/22 09:51AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/07/22 10:09AM
  Re: Restoring a 1978 Motobecane 50VRe: Satan 666 Satan 666 12/07/22 10:53AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/07/22 11:56AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 06:52PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 06:58PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/07/22 06:58PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 07:07PM
  Re: Restoring a 1978 Motobecane 50VRe: P D P D 12/07/22 07:24PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 07:53PM
  Re: Restoring a 1978 Motobecane 50VRe: Satan 666 Satan 666 12/08/22 12:06PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/08/22 12:45PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/07/22 07:32PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 08:00PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/07/22 08:07PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 08:15PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/07/22 08:27PM
  Re: Restoring a 1978 Motobecane 50VRe: Gen Xer Gen Xer 12/07/22 11:23PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/08/22 08:50AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/08/22 05:12PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike Boyd Mike Boyd 12/09/22 01:59PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/08/22 05:21PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/09/22 12:51PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/09/22 01:26PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/09/22 01:50PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/09/22 01:51PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/09/22 04:08PM
  Re: Restoring a 1978 Motobecane 50VRe: Stephen Keller Stephen Keller 12/09/22 06:33PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/10/22 05:56PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/10/22 05:52PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/10/22 06:09PM
  Re: Restoring a 1978 Motobecane 50VRe: Ed D Ed D 12/10/22 09:07PM
  Re: Restoring a 1978 Motobecane 50VRe: Richard Eberline Richard Eberline 12/11/22 01:50PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/11/22 09:51PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/12/22 06:41PM
  Re: Restoring a 1978 Motobecane 50VRe: Richard Brawner Richard Brawner 12/14/22 07:19PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/14/22 11:38PM
  Re: Restoring a 1978 Motobecane 50VRe: Richard Eberline Richard Eberline 12/15/22 07:02AM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/15/22 08:35AM
  Re: Restoring a 1978 Motobecane 50VRe: Moped Lar Moped Lar 12/15/22 09:49AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/16/22 07:22PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/16/22 07:30PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/21/22 05:59PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/21/22 08:28PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/22/22 01:05AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/22/22 08:56AM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/22/22 10:08AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/22/22 11:57AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/22/22 12:39PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/22/22 01:24PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/30/22 05:46PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/30/22 08:04PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/30/22 11:25PM
  Re: Restoring a 1978 Motobecane 50VRe: Gen Xer Gen Xer 12/30/22 11:42PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/31/22 12:39PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/30/22 05:54PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/31/22 01:01PM
  Re: Restoring a 1978 Motobecane 50VRe: Gen Xer Gen Xer 12/31/22 04:52PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 01/01/23 04:08PM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 01/03/23 08:08AM
  Re: Restoring a 1978 Motobecane 50VRe: P D P D 01/03/23 08:44AM
  Re: Restoring a 1978 Motobecane 50VRe: Gen Xer Gen Xer 01/03/23 09:02AM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 01/03/23 12:08PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 01/05/23 12:46AM
  Re: Restoring a 1978 Motobecane 50VRe: Dwayne S Dwayne S 01/03/23 08:20PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 01/03/23 08:26PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 01/05/23 12:40AM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 01/03/23 09:07PM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 01/03/23 10:33PM
  Re: Restoring a 1978 Motobecane 50VRe: Stephen Keller Stephen Keller 01/04/23 01:29AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 01/07/23 07:04PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/11/23 07:43PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/11/23 07:45PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/11/23 07:53PM
  Re: Restoring a 1978 Motobecane 50VRe: P D P D 04/12/23 09:08AM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 04/12/23 10:51AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/12/23 11:47AM
  Re: Restoring a 1978 Motobecane 50VRe: Gen Xer Gen Xer 04/12/23 09:47AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/12/23 11:42AM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 04/12/23 10:45AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/12/23 11:45AM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 04/12/23 12:12PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/13/23 07:54PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/12/23 11:33AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/16/23 05:43PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/16/23 05:55PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/16/23 05:59PM
  Re: Restoring a 1978 Motobecane 50VRe: P D P D 04/16/23 08:01PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/16/23 10:28PM
