Re: Restoring a 1978 Motobecane 50V
Bob Chesarek /
Restored the rear brake control / choke / on-off / horn assy. today as well as fitting front and rear brake cables. There is a before and after photo. Also the ckoke lever was bent so I straightened that while I had it apart.
There are some modifications required to the Treats Puch cable sets in order to complete the installation. On the front brake setup, I drilled the top cable adjuster a little larger as the metal end of the cable would not fit in, now it's good. Had to cut off the big knarp on the one end of the inner cable after soldering the cable to keep it together. I used the small end to go in the brake lever. Also had to cut off about 3" of cable outer as it was too long. Fit everything together and used a big knarp on the frt. brake arm to lock the cable down. Works as it should now. (edited)
  Restoring a 1978 Motobecane 50VTopic by: Bob Chesarek Bob Chesarek 12/07/22 01:32AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/07/22 07:32AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 09:24AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/07/22 09:45AM
  Re: Restoring a 1978 Motobecane 50VRe: P D P D 12/07/22 09:51AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/07/22 10:09AM
  Re: Restoring a 1978 Motobecane 50VRe: Satan 666 Satan 666 12/07/22 10:53AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/07/22 11:56AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 06:52PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 06:58PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/07/22 06:58PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 07:07PM
  Re: Restoring a 1978 Motobecane 50VRe: P D P D 12/07/22 07:24PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 07:53PM
  Re: Restoring a 1978 Motobecane 50VRe: Satan 666 Satan 666 12/08/22 12:06PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/08/22 12:45PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/07/22 07:32PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 08:00PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/07/22 08:07PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/07/22 08:15PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/07/22 08:27PM
  Re: Restoring a 1978 Motobecane 50VRe: Gen Xer Gen Xer 12/07/22 11:23PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/08/22 08:50AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/08/22 05:12PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike Boyd Mike Boyd 12/09/22 01:59PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/08/22 05:21PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/09/22 12:51PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/09/22 01:26PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/09/22 01:50PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/09/22 01:51PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/09/22 04:08PM
  Re: Restoring a 1978 Motobecane 50VRe: Stephen Keller Stephen Keller 12/09/22 06:33PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/10/22 05:56PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/10/22 05:52PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/10/22 06:09PM
  Re: Restoring a 1978 Motobecane 50VRe: Ed D Ed D 12/10/22 09:07PM
  Re: Restoring a 1978 Motobecane 50VRe: Richard Eberline Richard Eberline 12/11/22 01:50PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/11/22 09:51PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/12/22 06:41PM
  Re: Restoring a 1978 Motobecane 50VRe: Richard Brawner Richard Brawner 12/14/22 07:19PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/14/22 11:38PM
  Re: Restoring a 1978 Motobecane 50VRe: Richard Eberline Richard Eberline 12/15/22 07:02AM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/15/22 08:35AM
  Re: Restoring a 1978 Motobecane 50VRe: Moped Lar Moped Lar 12/15/22 09:49AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/16/22 07:22PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/16/22 07:30PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/21/22 05:59PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/21/22 08:28PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/22/22 01:05AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/22/22 08:56AM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/22/22 10:08AM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/22/22 11:57AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/22/22 12:39PM
  Re: Restoring a 1978 Motobecane 50VRe: Ryan Sadler Ryan Sadler 12/22/22 01:24PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/30/22 05:46PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 12/30/22 08:04PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/30/22 11:25PM
  Re: Restoring a 1978 Motobecane 50VRe: Gen Xer Gen Xer 12/30/22 11:42PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/31/22 12:39PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/30/22 05:54PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 12/31/22 01:01PM
  Re: Restoring a 1978 Motobecane 50VRe: Gen Xer Gen Xer 12/31/22 04:52PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 01/01/23 04:08PM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 01/03/23 08:08AM
  Re: Restoring a 1978 Motobecane 50VRe: P D P D 01/03/23 08:44AM
  Re: Restoring a 1978 Motobecane 50VRe: Gen Xer Gen Xer 01/03/23 09:02AM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 01/03/23 12:08PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 01/05/23 12:46AM
  Re: Restoring a 1978 Motobecane 50VRe: Dwayne S Dwayne S 01/03/23 08:20PM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 01/03/23 08:26PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 01/05/23 12:40AM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 01/03/23 09:07PM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 01/03/23 10:33PM
  Re: Restoring a 1978 Motobecane 50VRe: Stephen Keller Stephen Keller 01/04/23 01:29AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 01/07/23 07:04PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/11/23 07:43PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/11/23 07:45PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/11/23 07:53PM
  Re: Restoring a 1978 Motobecane 50VRe: P D P D 04/12/23 09:08AM
  Re: Restoring a 1978 Motobecane 50VRe: Mike McScoutington Mike McScoutington 04/12/23 10:51AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/12/23 11:47AM
  Re: Restoring a 1978 Motobecane 50VRe: Gen Xer Gen Xer 04/12/23 09:47AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/12/23 11:42AM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 04/12/23 10:45AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/12/23 11:45AM
  Re: Restoring a 1978 Motobecane 50VRe: Douglas Mackinnon Douglas Mackinnon 04/12/23 12:12PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/13/23 07:54PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/12/23 11:33AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/16/23 05:43PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/16/23 05:55PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/16/23 05:59PM
  Re: Restoring a 1978 Motobecane 50VRe: P D P D 04/16/23 08:01PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 04/16/23 10:28PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 07/25/23 12:29AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 07/25/23 12:36AM
  Re: Restoring a 1978 Motobecane 50VRe: Stephen Keller Stephen Keller 07/25/23 02:03PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 07/25/23 02:17PM
  Re: Restoring a 1978 Motobecane 50VRe: Paul H Paul H 07/25/23 07:46AM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 07/27/23 12:54AM
  Re: Restoring a 1978 Motobecane 50VRe: Paul H Paul H 07/29/23 12:17PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 07/31/23 01:20PM
  Re: Restoring a 1978 Motobecane 50VRe: Curly T Curly T 07/25/23 12:42PM
  Re: Restoring a 1978 Motobecane 50VRe: Bob Chesarek Bob Chesarek 07/27/23 12:58AM
