Hello, I tried removing the head and cylinder from my sons A35 yesterday and the head came off pretty easy but the cylinder is really stuck. The piston moves and the moped runs so a stuck piston is not the cause. The studs had some corrosion on them when I removed the head so my guess is that the studs have corrosion inside the cylinder and that is causing the issue. What is the best way to remove a cylinder when this is the case. I suspect the rod bearing or piston pin has some play in it since this engine has an odd noise in it so I wanted to check it out since we just bought this moped a few days ago. Also, I wanted to buy the Viton seals from treatland but they are out of stock, what is the next best option. Thanks.
