> P D wrote:
> Replace the condenser .
> Do the following . The instructions are for Puch , but basically the
> same for any moped .
> https://www.mopedarmy.com/wiki/Install_an_external_condensor_on_a_Puch
This ^^^^^^ also make sure the wire from the points that attached to the hot coil has a good connection on the hot coil prong. Like actually take it off, clean the hot coil spade prong and make sure the connector has a TIGHT connection. Also check the hot coil ground to the frame. Remove the plug boot and trim a little of the plug wire off and reinstall the boot. If all this fails then clean the points.
