In your other post about the cap falling off it seems the shop isn't the greatest. Also could be a chance that when they put the front wheel on it needed a spacer and they just cranked the nuts down and now the forks are binding as they are not parallel to each other? Loosen the bolts on the wheel and see what happens? Also could be the opposite. They may have pryed them open to make them fit. I had a set of those before and was not super impressed with them. They didn't have much travel at all and you had to have the fork brace or they would twist bad.
