Re: Play in Front Forks of the Puch Free Spirit
Kelikaku קוטין /
> Matt Mulligan wrote:
> ... the fact that magnum ii and free spirit forks are identical. ...
> ... I'm pretty sure they measure to 27 inches. ...
Thanks. I really am curious to see how they measure out!
According to Treatland, the Magnum ll are identical to the Free Spirit 'Deluxe' but the other two Free Spirits have their own forks, as do Maxis, Magnums, and Magnum lls. This is also reflected in the repair manual, there are definitely three different sets of Free Spirit forks, depending on what model. There is a note at the bottom of one of the descriptions, in the feedback section:
They describe Magnums as being 27" and Maxis as being 23".
When I measured my forks, from the centre of the axel and the bottom of the upper triple tree, they measured 25 3/8" or just under 25.5".
I'd like to see how your Magnum ll forks measure out, since according to the above chart, they aren't the same as both the Magnum Mk ll, Magnum XK, the Maxi and the original Magnum. If the Magnum ll's are the same as the Free Spirit Deluxe, then they should only be around 25.5", not 27".
I'm concerned, because even only adding 1.5" to the fork length may mean issues with cables getting too short or needing to be replaced or rerouted; as well the reviewers reporting that after replacing shorter forks with longer ones meant that the cycle couldn't be started on the stand any more, due to the rear wheel being forced down too close to the pavement. But subtracting 2.5" from the fork length will mean less ground clearance for going over bumps.
I don't mind more ground clearance but I'm not prepared at this point to start fooling around with new cables. Also, if the forks are going to be extended 1.5" then my brand new shocks are now going to be a bit shorter than I'd like. Which means I may need a new chain if I get longer shocks.
So I'm trying to be careful about this and match the 25.5" length if and when I replace the forks.
  Play in Front Forks of the Puch Free SpiritTopic by: Kelikaku קוטין Kelikaku קוטין 08/14/22 09:05PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Graham Motzing Graham Motzing 08/19/22 12:21PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Jay Rivett Jay Rivett 09/14/22 09:42AM
  Re: Play in Front Forks of the Puch Free SpiritRe: Matt Mulligan Matt Mulligan 09/14/22 04:24PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 09/14/22 06:46PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Mike Boyd Mike Boyd 09/14/22 07:18PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 09/15/22 12:30PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Matt Mulligan Matt Mulligan 09/14/22 09:18PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 09/15/22 10:41AM
  Re: Play in Front Forks of the Puch Free SpiritRe: Mike Boyd Mike Boyd 09/15/22 12:53PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 09/15/22 08:45PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 02/05/23 04:52PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Full Tuck Full Tuck 08/19/22 12:45PM
  Re: Play in Front Forks of the Puch Free SpiritRe: james snovel james snovel 08/19/22 06:10PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 09/11/22 02:19PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 09/11/22 02:31PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 09/13/22 05:54PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Mike Boyd Mike Boyd 09/11/22 02:44PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Seth B Seth B 09/12/22 08:38AM
  Re: Play in Front Forks of the Puch Free SpiritRe: Mike Boyd Mike Boyd 09/12/22 12:58PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Chad Tufts Chad Tufts 09/12/22 10:43PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 10/21/22 05:10PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 10/31/22 10:01AM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 11/08/22 10:18AM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 11/10/22 02:36PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Jay Rivett Jay Rivett 02/05/23 05:07PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kim Jong illest Kim Jong illest 11/11/22 07:32AM
  Re: Play in Front Forks of the Puch Free SpiritRe: Kelikaku קוטין Kelikaku קוטין 11/28/22 03:05PM
  Re: Play in Front Forks of the Puch Free SpiritRe: Satan 666 Satan 666 11/30/22 01:15PM
