> Totally normal JBOT wrote:
> Solder works great for pinholes too. Don’t even need to add a patch. You
> can even use a soldering iron without any issues if you don’t have a
> torch since gas tank sheet is so thin.
> But I generally patch with a sandwiched patch for added strength
Yup. Soldered up a few dozen pinholes in a Bravo tank with a soldering gun. Worked slick, one hole at a time. Then sanded the high spots. Just gotta Bondo & paint now.
