> Totally normal JBOT wrote:
> > Justabunchoftrash 646260 wrote:
> > It’s a bad idea
> Just like taking any advice you give as facts lol
> I’m gonna make a videooooooo with a big hole soldered up on a tank to
> put this issue to bed.
> You won’t believe how easy it is. For a hole, cut a piece of sheet just
> a tad bigger than said hole. Then clean the areas well, remove all
> paint.
> Then tin the tank and tin the piece of sheet metal separately before you
> attach together. Then place the disc on the tinned hole then just melt
> em together. It’s that easy
Look a frame is a $100 bucks.,. That hole is way to big! End of story bye
