> Justabunchoftrash 646260 wrote:
> It’s a bad idea
Just like taking any advice you give as facts lol
I’m gonna make a videooooooo with a big hole soldered up on a tank to put this issue to bed.
You won’t believe how easy it is. For a hole, cut a piece of sheet just a tad bigger than said hole. Then clean the areas well, remove all paint.
Then tin the tank and tin the piece of sheet metal separately before you attach together. Then place the disc on the tinned hole then just melt em together. It’s that easy
