Re: Motobecane tank repair
Cheap ???
Remember , you get what you pay for .
Use Caswell's or RedKote . Follow the instructions to the T . No short cuts .
Totally normal JBOT /
You have to hold the torch further away. Red hot is way too hot. Solder only needs a propane torch
Kevin Hurt wrote:
> I wire wheeled it really good. Cleaned it with brake clean. Tried flux
> core solder. Tried hard silver solder with mapp gas. I don’t think I
> want to make new steel patches and try to braze it with oxy/acetylene.
> It gets red hot with mapp gas in a second because it’s so thin. So I’m
> just going to drill out my rivets and I’m back to jb welding my patches
> on, but thanks for all the advice. (edited)
Kelikaku קוטין /
> Kevin Hurt wrote:
> Link to cheap sealer? ...
I went on Amazon, it looks like the kit to get probably is 'Caswell'.
https://www.amazon.com/dp/B0722QRPB7/
That's a "deluxe" kit - this is the one you're going to want, it has the sealer but there's the extra 'masking liquid' in there which is used to temporarily patch breaches (and that hole in your tank is a BREACH!) so that the sealer will stay in the tank. The masking liquid will provide a surface for the sealer to attach to; then after the sealer is cured, the procedure is to remove the temporary mask.
It looked like from your photos that the patch you riveted on would have been a good start to mask that huge hole. The only thing I might have suggested is; either use a body-working spoon and hammer, to straighten out the edges of the breach - OR - remove the rough edges of the breach, and cut them out, or grind them out, to make the edges tidy, so it can be repaired. Then put the mask over that area; but with a hole that large, you need that patch that you made; I'd say you can use duct tape too, with the masking liquid over it to prevent the sealer from leaking out. Remember your patch could be temporary or permanent, but the masking liquid is temporary and after the sealing is cured, it's to be removed. I thought your patch looked kind of neat, and it appeared that you could leave it on after sealing, if you liked its appearance. If you remove all the masking, you could simply sand and paint over the sealing and it should become invisible.
The main issue with the sealer, in your specific case, is, the sealing process requires that the tank be rotated in all directions to ensure that the sealer can get to every corner of the tank. Your tank is part of the entire frame. So you have to figure out a way to rotate the entire frame with the sealing liquid inside the tank. You're probably going to have to either strip the frame and hang it up somewhere that will allow that. I don't think you'd want to try anything else (like cutting the frame away from the tank portion, sealing the tank, and welding the frame back together after the tank is sealed).
The sealing kit seems to include more than enough for one coat of a three gallon tank, and it seems to me like you're better off using more than one coat in some cases, where there's a lot of internal damage. You should test the repair out with some solvent or even water before you put fuel back in the repaired tank.
I found a few videos on YouTube, most of them are between 15-20 minutes long. There's also a playlist, four parts, of a repair process, each part is an average of 8-9 minutes, with the longest being under 13 minutes.
This kit costs $60. It seems like the offer you got to pick up a donor frame may be almost as much work as stripping the frame you have and repairing the tank. Either way you have to strip the frame. You could do both. Use the donor frame as a rider while you repair the tank on the original.
I found it kind of interesting. The epoxy sealer seals hard and cures with some flexibility. The trick is to get the sealer to flow inside the surface of the tank, over every internal surface. Which requires that the user turn and rotate the tank while the sealer is still liquid, before it solidifies. When your frame and tank are integrated, this makes it very, very, interesting. How are you going to flip that entire frame around to get the sealer to cover everything? Maybe do one side first then do the other side? That huge breach should be the priority of course.
Good luck with it. Keep us updated!
Playlist (five videos):
https://youtube.com/playlist?list=PL91A3D70222F080AF
Two other videos (by same content creator):
בס'ד
^^^we gotta make use of this K tldr dude for superficial research. I mean not all people have the time or put in the effort to cut n paste wo ever touching anything.
operator error 696 420 /
Make sure to seal the tank first then paint!
I use por15 and vinegar!
The vinegar might eat away at the jbweld but don’t worry to much about it, i usually get away with sealing the tank the reapplying jbweld! Use the quick set jbweld you’ll save a lot of time!
The por15 will expand so don’t be surprised if the pin holes look like expansion foam just sand them down! Two coats of tank sealer especially with jbweld is not a bad idea, it might save your ass from a really Bad situation!
The best motorcycle fire goes to billy lane hands down! (edited)
Douglas Mackinnon /
I’m afraid the gaps between the 2 metals are too large for capillary action to draw solder in. Especially at the bottom. Steel on steel with arc welder is your only hope.
You’re totally obviously wrong.
Stop bullshitting
D
Douglas Mackinnon /
Prove me wrong by making it work with solder. Maybe you use on if your shampoo bottle contraptions.
I managed to solder steel mounting brackets to brass radiator tanks without much trouble so I dont see why this would be any different.
Douglas Mackinnon /
Prove me wrong by making it work for him, that tank is probably FUBAR anyways but I can appreciate his effort. Very unlikely you or anybody else is going to seal copper to steel with a handful of aluminum rivets in the mix which would melt well before the solder. And, of course, make it all fuel tight. The act of heating that tank will likely open more holes in the steel anyways. Maybe you can build him a ghetto tank out of a shampoo bottle.
🦺🥇b to the MOPO 🚨🚨🚨 eff /
Uhh, the most commonly used solder alloys melt at like 360°F
Aluminum melts at 1221°F
Douglas Mackinnon /
The discussion was leaning toward silver soldering of dissimilar metals. Silver solder has melting points of 1150-1650f depending on content.
Soft solder won’t stick to steel any better than it sticks to wood.
I do see he said he tried hard silver solder, my bad there.
Tin based solder (leaded or lead free) absolutely will stick to steel if the surface is clean and you use an acid-based flux. Hell, you can even solder galvanized if you're good.
Many companies that make solder and flux have useful guides for using their products. Here is one that covers soldering aluminum, stainless steel, and nickel: https://www.kappalloy.com/pub/media/pdf/Kapp%20solder%20instructions%20R6.pdf
These metals are a bit tricky to solder, but with the right solder, the right flux, and the right technique, it's totally doable.
If you go the jbweld route. Get the water weld version of jbweld. It is kind of like a putty and it works well on gas tanks. I know someone who has had it on a cimatti tank for over a decade.
Kelikaku קוטין /
>... Silver solder has melting points of 1150-1650f ...
Wrong, camel breath! Silver has a melting point higher than aluminium true.
However, if you observe the photo that the OP posted:
https://www.mopedarmy.com/forums/file.php?6
You will see that this silver solder has a melting point of 420°F, TOO LOW to melt aluminium:
Prove me wrong.
Yes I will use on if my shampoo contraption Einstein
You just heat the steel with propane, then rub solder on it. If it doesn’t melt heat more. It’s about as easy as possible.
Now the rivets we don’t know whether they were aluminum or steel. But they are easy enough to swap out if the op made that mistake.
Solder is cool shit, it can fill gaps as well if you do it right. Just gotta practice with the propane torch, and position the work flat so the melted solder doesn’t run off.
Lol. Are you serious? Silver bearing solder, electrical solder, they all stick to steel very well. Again with the bullshit I guess
And of course let’s not forget every fucking soft solder ball end on most every brake or throttle cable on mopeds. It’s a low temp solder attached to steel.
Braze the fucker with brass!!
Kevin Hurt /
Let’s just chill out, this thing ain’t going to the moon. I didn’t even try that silver bearing solder that I blew up about. The solder I did use I did get to stick when it was perfectly flat over wise it would just run off. With the curves in the tank it wasn’t going to happen for me. The hard silver solder is different and would only melt with mapp gas. Again it didn’t work for me. The rivets are steel and my patches are jb welded and riveted on. I’ll let you know how it goes when I get it back together. Thanks
What flux are you using?
Kevin Hurt /
Some stuff from a plumber friend. I also tried some radio shack rosin core solder I had. Thanks
It’s a bad idea
Kevin Hurt /
Fair dinkum
> Justabunchoftrash 646260 wrote:
> It’s a bad idea
> It’s a bad idea
Just like taking any advice you give as facts lol
I’m gonna make a videooooooo with a big hole soldered up on a tank to put this issue to bed.
You won’t believe how easy it is. For a hole, cut a piece of sheet just a tad bigger than said hole. Then clean the areas well, remove all paint.
Then tin the tank and tin the piece of sheet metal separately before you attach together. Then place the disc on the tinned hole then just melt em together. It’s that easy
> > It’s a bad idea
> paint.
Look a frame is a $100 bucks.,. That hole is way to big! End of story bye
Kevin Hurt /
Hell yeah Jbot! I want to learn new things and it’s not like I made it worse. I just want to ride the thing and if it leaks I can fix it proper.
Soldered Patch video. Not my vid but the principle works the same regardless of size of patch
