Clean it with acetone then scratch up a bunch, then lay it flat as solder likes to run. Heat metal til solder melts on its surface and sticks.
Most silver bearing solder has internal flux so heat the metal and then apply. Doesn’t have to get that hot.
If that sheet is stainless you might have a hard time but it will probably still stick
