Hello! I was experiencing intermittent spark, now non-existent. Currently I have the motor in a vice, with everything grounded to the intake studs. Timed to 1.3mm BTDC
I read up to 50 volts from the wires to the HT Coil, but get almost nothing after the HT Coil. HT Coil shows continuity between the poles. Kill switch and lights are disconnected.
Can I swap in any old ignition coil to rule out my Turkey Baster? Or is there somewhere else I should be checking with my DMM? I have a new CDI Box on the way, but I'm in Canadaland, and impatient.
Thanks!
