Re: Variator sticking - Mobylette AV7
The Operative /
Here are few more shots. Normal position of the fork of the moving pulley halve low gear (not variated). The pin from the variator housing located inside the fork normally:
Now, here is the position the variator gets stuck in fully variated. The fork move nearly completely past the pins and hangs up:
One of the 3 rollers can also come out of it slot and jam the variator fully open....this has happened:
So how do I stop the pulley fork from escaping the end of the pin? Is this a manufacturing error?
Any advice appreciated.
T.O.
