Re: Av10 Help
Totally normal JBOT /
> Jesse Nordlander wrote:
> Just mount the cylinder in lathe, take off 2mm off top for starters
Unless one has a proper cyl jig or center clamping fixture, a mill is much quicker to cut cyl top.
Lathes are a pita to use to cut the top of cyl.
The base of the cyl on the other hand is easy on a lathe cuz you can just grab the bore in the chuck
