I am cleaning the variator on a Hobbit and it “looks” like the bearing is worn. How you you remove the bearing and if it is worn are there replacements available. Or should I just clean and relube it and leave well enough alone. Thanks Jack.
Ah Spring - 48 degrees, cloudy and windy.
