Almost there... I hope...
1995 Hero-Majestic Panther Moped
The carb is cleaned. Completely. Twice.
Gas tank cleaned. 50:1 as prescribed.
New fuel lines.
Exhaust cleaned.
Filter cleaned.
Spark plug fires. New plug.
I was having troubles with the ignition key. Turns out it wasn't hooked up. I put a switch on and rewired it.
Check all the grounds. Changed a few connections that looked bad.
NOTHING. Tried pedaling for as long as I could many times.
Spark plug us wet, and it sparks when I test it. Its not wet with straight gas. Its kind
of rust colored.
Any help would be beyond appreciated guys. Thank you for any help in advance!
Re: Almost there... I hope...
decomp leaks pretty likely.
whats your jet?
also still a spark issue is possible.
I'd try gas off, maybe even carb off and see if it fires up with starter fluid, if yes, you know its a fuel issue and if no, it's probably NOT a fuel issue and spark or compression (again - decomp?)
could also be bottom end compression, maybe a leakdown is due but easy stuff 1st
