Throttle cable help for 1979 Express 2
I ordered the level 1 big bore kit from treat land. It came with the Dellorto sha 15.15 carb and new throttle cable. The white plastic piece that retains the cable housing on the stock cable does not come off to put it on the new throttle cable that came with the kit. How does the new throttle cable attach to the throttle body under the kill switch? Without the original plastic piece the cable just floats around. Any help would be greatly appreciated. Thank you
Re: Throttle cable help for 1979 Express 2
Looks like that plastic cable adjuster is threaded? I would measure the diameter and thread pitch then try to find a slotted cable adjuster that matches. Like these.
