So compression tester is suspect. A motor wont run on 40 lbs. Im suspecting air fuel mixture.
Did the oil injectuon last 12k too? Did you delete and not cap off the nipple on intake manifold.
Does the plug get soaking wet? Look for fuel deluvery and definitely look into changing out your crank seals n clutchs.
