Re: I’m incompetent
Gerald Scott /
Well, you have part of a moped. It's missing the front and rear fender, side covers, tail/brake light, but more importantly it's missing the entire air cleaner assembly, which is made up of a whole bunch of parts All those parts at the bottom of the diagram, below the black triangle on the right https://www.mopedjunkyard.com/TOMOS-A35-DELLORTO-Carb-Parts-Diagram-Ref-T7c_c_532.html
It has what looks like a Biturbo or similar exhaust, and the fact that the cylinder is aluminum instead of being painted black like the rest of the engine probably has a big bore kit. Hopefully nobody tried to do any homespun porting on it.
With a setup like that, the engine will need more fuel and air than the stock jetting and air cleaner can provide. You could get away with a pod type foam air filter that attaches directly to the carb. It would help to know how many cc the cylinder is. It might actually be stamped into the cylinder somewhere. You definitely need to remove the carb and take it apart. It is probably filthy inside, if the outside is any indication. The float needle is definitely leaking. It probably needs a new one. I use spray Berrymans B-12 or Gumout carb cleaner and guitar strings to clean out all the small passages. DON'T get carb cleaner in your eyes.
Check the jet and see what number it is. Stock jet should be a #53, but with a low restriction air filter, an expansion chamber exhaust, and possibly a big bore kit, it will need a larger jet. I would start with fixing that leak in the carburetor. It is never going to run right with it leaking like that. That might actually be most of what is wrong with it. It probably needs a little tuning, and there is no shortcut there. It is done by trial and error. Just think of it as a fun learning experience.
  I’m incompetentTopic by: Mike Massa Mike Massa 05/06/22 06:14PM
  Re: I’m incompetentRe: Mike Massa Mike Massa 05/06/22 06:16PM
  Re: I’m incompetentRe: LSLB RXb LSLB RXb 05/06/22 06:21PM
  Re: I’m incompetentRe: Den 23 Den 23 05/06/22 08:29PM
  Re: I’m incompetentRe: Mike Massa Mike Massa 05/06/22 08:41PM
  Re: I’m incompetentRe: Brian Solex Brian Solex 05/06/22 08:49PM
  Re: I’m incompetentRe: Mike Massa Mike Massa 05/07/22 08:28PM
  Re: I’m incompetentRe: LSLB RXb LSLB RXb 05/07/22 09:10PM
  Re: I’m incompetentRe: Den 23 Den 23 05/07/22 09:34PM
  Re: I’m incompetentRe: Chad Tufts Chad Tufts 05/06/22 09:35PM
  Re: I’m incompetentRe: b to the eff b to the eff 05/06/22 10:28PM
  Re: I’m incompetentRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/06/22 11:01PM
  Re: I’m incompetentRe: Jay Rivett Jay Rivett 05/07/22 10:40AM
  Re: I’m incompetentRe: Jay Rivett Jay Rivett 05/07/22 10:49AM
  Re: I’m incompetentRe: Bob Naske Bob Naske 05/08/22 05:41AM
  Re: I’m incompetentRe: Ike Pipe Ike Pipe 05/08/22 12:10AM
  Re: I’m incompetentRe: LSLB RXb LSLB RXb 05/08/22 03:18PM
  Re: I’m incompetentRe: b to the eff b to the eff 05/08/22 12:46AM
  Re: I’m incompetentRe: evgdboy X evgdboy X 05/08/22 04:35PM
  Re: I’m incompetentRe: baird co baird co 05/09/22 03:07AM
  Re: I’m incompetentRe: b to the eff b to the eff 05/09/22 10:56PM
  Re: I’m incompetentRe: baird co baird co 05/10/22 02:47AM
  Re: I’m incompetentRe: Jay Rivett Jay Rivett 05/10/22 11:14AM
  Re: I’m incompetentRe: Dirty30 Dillon Dirty30 Dillon 05/10/22 12:27PM
  Re: I’m incompetentRe: baird co baird co 05/11/22 02:05AM
  Re: I’m incompetentRe: LSLB RXb LSLB RXb 05/11/22 07:47AM
  Re: I’m incompetentRe: baird co baird co 05/11/22 09:46AM
  Re: I’m incompetentRe: Hepatitis J [OFMC] Hepatitis J [OFMC] 05/11/22 09:46AM
  Re: I’m incompetentRe: Gerald Scott Gerald Scott 05/10/22 10:26AM
  Re: I’m incompetentRe: Hepatitis J [OFMC] Hepatitis J [OFMC] 05/10/22 10:32AM
  Re: I’m incompetentRe: Declan g Declan g 05/11/22 10:08AM
