Re: I’m incompetent
baird co /
> b to the eff wrote:
> > baird co wrote:
> > Did you put the air filter back on when you started it? SHA's are
> stupid
> > carbs. With no real adjustments, they use the filter as a way of
> > moderating the air flow, and usually won't idle without it on.
> This is not my experience. I've seen plenty of bikes with SHAs idle
> just fine without an air filter.
None of my stock bikes will. Or, sometimes they'll idle, but you rev them up and they just go, "bluuuurp..." and try to die. I've had bikes that I'd try to start over and over and get nothing, then put the filter on and it fires right up and idles.
You can mess around with jetting to make them work, especially with kitted or modified engines, but every stock, untouched bike I've had won't run well, if at all, without the filter.
That's why they have those weird air filters.
The stacked screens come in different mesh patterns, and the old style oblong plastic covers have indented circles molded into the plastic (or plugs) so you can punch them out to change the air flow.
Really low budget, inefficient way to meter the air, when just sticking a screw in the side would be much more effective.
I hate those shitty carbs.
  I’m incompetentTopic by: Mike Massa Mike Massa 05/06/22 06:14PM
  Re: I’m incompetentRe: Mike Massa Mike Massa 05/06/22 06:16PM
  Re: I’m incompetentRe: LSLB RXb LSLB RXb 05/06/22 06:21PM
  Re: I’m incompetentRe: Den 23 Den 23 05/06/22 08:29PM
  Re: I’m incompetentRe: Mike Massa Mike Massa 05/06/22 08:41PM
  Re: I’m incompetentRe: Brian Solex Brian Solex 05/06/22 08:49PM
  Re: I’m incompetentRe: Mike Massa Mike Massa 05/07/22 08:28PM
  Re: I’m incompetentRe: LSLB RXb LSLB RXb 05/07/22 09:10PM
  Re: I’m incompetentRe: Den 23 Den 23 05/07/22 09:34PM
  Re: I’m incompetentRe: Chad Tufts Chad Tufts 05/06/22 09:35PM
  Re: I’m incompetentRe: b to the eff b to the eff 05/06/22 10:28PM
  Re: I’m incompetentRe: EH 📣FCC of the QCB EH 📣FCC of the QCB 05/06/22 11:01PM
  Re: I’m incompetentRe: Jay Rivett Jay Rivett 05/07/22 10:40AM
  Re: I’m incompetentRe: Jay Rivett Jay Rivett 05/07/22 10:49AM
  Re: I’m incompetentRe: Bob Naske Bob Naske 05/08/22 05:41AM
  Re: I’m incompetentRe: Ike Pipe Ike Pipe 05/08/22 12:10AM
  Re: I’m incompetentRe: LSLB RXb LSLB RXb 05/08/22 03:18PM
  Re: I’m incompetentRe: b to the eff b to the eff 05/08/22 12:46AM
  Re: I’m incompetentRe: evgdboy X evgdboy X 05/08/22 04:35PM
  Re: I’m incompetentRe: baird co baird co 05/09/22 03:07AM
  Re: I’m incompetentRe: b to the eff b to the eff 05/09/22 10:56PM
  Re: I’m incompetentRe: baird co baird co 05/10/22 02:47AM
  Re: I’m incompetentRe: Jay Rivett Jay Rivett 05/10/22 11:14AM
  Re: I’m incompetentRe: Dirty30 Dillon Dirty30 Dillon 05/10/22 12:27PM
  Re: I’m incompetentRe: baird co baird co 05/11/22 02:05AM
  Re: I’m incompetentRe: LSLB RXb LSLB RXb 05/11/22 07:47AM
  Re: I’m incompetentRe: baird co baird co 05/11/22 09:46AM
  Re: I’m incompetentRe: Hepatitis J [OFMC] Hepatitis J [OFMC] 05/11/22 09:46AM
  Re: I’m incompetentRe: Gerald Scott Gerald Scott 05/10/22 10:26AM
  Re: I’m incompetentRe: Hepatitis J [OFMC] Hepatitis J [OFMC] 05/10/22 10:32AM
  Re: I’m incompetentRe: Declan g Declan g 05/11/22 10:08AM
