Yes the clutch rotates fine. The shaft that the gear is on that spins the rear wheel spins until the transmission is engaged. Everything in the engine rotates, nothing is seized. It’s a gear problem connected to the rear chain. Like a broken tooth on a gear. The engine didn’t seize I’m positive of that. Thank you for your advice and opinion.
