Hello, I need help with the moped Piaggio Ciao.When I start the moped downhill and at high revs it goes, but at low revs it turns off, uphill does not go up with a low rev
Here is video
Here is video
Idle screw adjustment, also make sure idle jet hole under throttle is clear below slide.
Other than that low compression which could be a few things.
How much have you done to the bike? Is it stock? Have you fixed anything?
If you have done nothing to it, I'd recommend changing the crank seal. That's the thing that will make it hard to climb hills. Other air leaks can also be the issue.
Hello, there are a lot of things replaced ignition hammer, coil, new cylinder and piston, new gufero, I split the gasket into a crank and there was a silicone gasket , so I ordered a new gasket has not yet come until the next I will let you know thank you for the answer it is from the translator (edited)
. (edited)
