Re: Piaggio Ciao Does not hold low revs
jezdec pobočky /
Hello, there are a lot of things replaced ignition hammer, coil, new cylinder and piston, new gufero, I split the gasket into a crank and there was a silicone gasket , so I ordered a new gasket has not yet come until the next I will let you know thank you for the answer it is from the translator (edited)
