Re: Piaggio Ciao Does not hold low revs
Ike Pipe /
How much have you done to the bike? Is it stock? Have you fixed anything?
If you have done nothing to it, I'd recommend changing the crank seal. That's the thing that will make it hard to climb hills. Other air leaks can also be the issue.
