Huret Speedo on Moby 50v - should I get rid of speedo bulb?
So I’m currently in the process of fixing up this 1979 Motobecane 50V and I’ve heard stories of people having their dashes melt due to the dash bulbs and I was wondering if I should take them out to avoid this? Or should it be fine? Currently it has 1 bulb in it so I’m wondering if I should take it out or get two new ones. Also what volt should the bulb be? 6 volt or 12?
Re: Huret Speedo on Moby 50v - should I get rid of speedo bulb?
Pushrod Fifty /
They are fine as stock just read the number off of the bulb. They are really bright and a little annoying on a dark road but never burned the face.
there are LED versions of this lamp available
I believe at LEDTRONICS be sure you get the correct voltage and base size...there are lots that look similiar. Look up B320-XIW-6/48V
