Piaggio ciao does not idle and does not have power
jezdec pobočky /
hello, I have a moped Piaggio Ciao moped starts but does not have power and does not hold idle,carburetor is not dirty.
Re: Piaggio ciao does not idle and does not have power
check compression, i had a za50 that would start but wouldn't stay had a broken ring
Look for air leaks. If you can get it running, spray starting fluid on the engine near the carb, see if you have huge air leaks. If it accelerates with starting fluid sprayed between the carb and case, or on top, you've bot leaks. Even where the cable goes into the carb at the top, it should have a cover over the cable to the carb.
Crank seal. Change it.
