Re: 1978 Garelli
Have you checked engine compression? It might be suffering from low compression.
Re: 1978 Garelli
Just to eliminate a variable, your clutch cable is fine at both ends and there's no slippage or anything funny going on there? On my Garelli Basic 50 someone had used a fuse block terminal as the knarp and it was hanging up on the frame.
Re: 1978 Garelli
The woodruufff key is small and possibly sheared. Also change that side crank seal while checkin/changing. 17/35/7
Your choke working right? Your rear brake light working?
Re: 1978 Garelli
Do mopeds have a brake light any place but the rear ? ;)
Re: 1978 Garelli
You couldn't help it could you 😅
Re: 1978 Garelli
Ha . Inquiring minds need to know . LOL
I guess I can't really blame him for supplying a thorough description . ;) (edited)
Re: 1978 Garelli
Hey guys, I just took apart intake and found there is only one piston ring on piston and piston has a crack on it. So I’m guessing this is a major compression issue so treats will be getting some more of my money! 😵‍💫
Re: 1978 Garelli
🤔 what does the cylinder look like?
Re: 1978 Garelli
Will take pics here in sec.
Re: 1978 Garelli
Pics of Cylinder
Re: 1978 Garelli
Looks like you'll be good with a piston kit and some gaskets.
Re: 1978 Garelli
I’d get the cylinder honed.
Re: 1978 Garelli
Okay. Thanks for replies
Re: 1978 Garelli
I see two rings . The lower ring is simply stuck in it's landing .
New rings require a cylinder hone .
Re: 1978 Garelli
I see the lower ring. The upper ring is missing along with a 1/4 of the upper ring land. I'd be looking for the missing peices before I put any new parts in that VIP motor. Mmmm mmm toasted. (edited)
Re: 1978 Garelli
You are right . I wasn't looking close enough . :(
Re: 1978 Garelli
VIP?
Re: 1978 Garelli
> the
> any
> VIP?
Its not an NOI nor is it mounted on a Monza frame. Its a step through vertical motor...
Re: 1978 Garelli
I'm hungry for a Quiznos sub now.
Dave Jenkins, please post a pic of the whole moped and or the vin tag on the steering neck. Thank you. (edited)
Re: 1978 Garelli
His first pics show the cases of an NOI. The pic I just posted looks like a VIP. So the O.P. needs to show us all an overall pic or vin tag to clarify. Most VIP motors were two speeds and this one is a one speed. (edited)
Re: 1978 Garelli
Woa! The first pics really make it look like a horizontal noi engine. But these last pics of the cyl and piston carnage, that is 100% a vip engine.
Not much changes for the rubber clutch info provided but they are definitely different engines.
Re: 1978 Garelli
I ordered a piston and ring for a NOI engine. Maybe that’s the problem Im having after assembly. (edited)
Re: 1978 Garelli
Bud, I would take a look at the repair guide for garelli in the wiki here and identify the specific motor you have. It will show you exactly which size piston and rings you will need.
Re: 1978 Garelli
U might wanna explain your problem...
By memory garelli is 40mmx2 rings. But digital calipers r necessary for this kinda stuff.
Re: 1978 Garelli
Welp, its a one speed horizontal noi motor and has 17" wheels. Most Garellis I've seen have 16" wheels.
(edited)
Re: 1978 Garelli
daan SJAARLOOS /
That looks like pretty severe detonation to me. Or something broke off and bashed the shit out of the piston. What does your head look like?
I'd make sure that all the metal crap that came off that piston is out of the case before you put anything back.
Re: 1978 Garelli
Thanks. Hey guys what does it mean when I can be walking my Garelli and the engine is engaging as if I’m paddling to start? What is not Dis-engaging
Re: 1978 Garelli
> Dis-engaging
The first thing I would do is to be damn sure the starter lever and its cable are not too tight. It could be that the starter clutch is not disengaging when you let off of the lever. The original starter cables were not adjustable and made to a predetermined length to prevent just this from happening. Over the years, some peeps will have replaced the starter cable with anything they could find that would fit. When that happens the cable tension will most likely be set too tight and the starter clutch wont disengage when you let off of the starter lever. I have had a couple such Garelli mopeds with this problem. Its very difficult to adjust the tension on the starter cable using the starter lever (on the handle bars)for "feel". Rather, I use the lever on the top of the motor just under the floor boards to set cable tension by feel. Best way to tell whats going on is to remove clutch cover and inspect the starter clutch cam for excessive wear. Here is a pic of what happens when someone sets the starter cable tension too tight. Its constantly engaged after the motor starts and fries the cam..
Re: 1978 Garelli
You can do it at the bars, just tighten it maybe a little too far, then pedal loosen, pedal and loosen untill the engine isn't engaging on its own. That should be good.
If it is difficult to engage the clutch to get the motor moving then the clutch friction material on the bell may be worn out.
Re: 1978 Garelli
I do not recommend that at all ^^^ because thats the way most peeps set it and get it too tight. Please try it my way once and tell me that you cant tell the difference.
