No spark on my old Moby
I have been working on my 58 Mobylette for some time and for whatever reason I can't get it to spark. I have installed a CDI unit, new coil and regulator.
The CDI unit has 4 wires coming out of it. Yellow, Green, Black and black with a red tracer. The Yellow wire goes to the regulator, yellow to yellow. Green to green out of the CDI control box. Black to ground and that leaves black/red to what? There is a red wire coming out of the CDI control box, is that what it hooks up to? The Black/white wire coming out of the control box is for the kill switch? Orange out of the control box goes to the coil?
I added an extra ground from the engine to the frame where all the other ground are attached.
Unless the coil is bad? I have no idea what is going on.
Ideas?
Thanks in advance.
John in Texas
Re: No spark on my old Moby
Richard Eberline /
Grounds have to be bare metal clean. The grounds are:
Stator AC coil. black wire
CDI Box. black wire
HT coil make a wire large terminal
Voltage regulator. black wire
Optional ground engine head to frame.
Black with white stipe is kill wire. Not needed use decomp.
Richard Eberline /
Black with red stripe goes to cdi box.
Orange to ht coil.
John Ebert /
Well I will go back and clean where the grounds all attach to the frame and build a ground strap from the frame to the engine. I had one going from one of the carb mounting studs to the frame. As someone said you can't have enough grounds.
Thanks
John in Texas
